raptor engine oil
Old Sep 26, 2002 | 01:36 PM
layjzay's Avatar
Anyone having trouble with engine oil burning off clutches?
When taking off slow where it requires to ride the clutch some in tight trails. After a while I loose about half my clutch lever travel. The bike still goes but the clutch lever has a lot of play in it but it does not slip. I have smoke that comes out of the crank breather so I think it is cooking the oil. After you ride a little without using the clutch the lever comes back to normal.
Would appreciate any help you can give!
Old Sep 26, 2002 | 01:54 PM
THEMOOSE's Avatar
It sounds like your using your clutch like a 2 stroke.
Use the torque of the engine instead of the clutch.
If you find yourself having to slip the clutch too much try changing the gear ratio so you don't have to.
What weight & brand of oil are you using?
Try 10w40 Yamalube, if you still have a problem try semi synthetic Yamalube.
Over all it sounds like your abusing the clutch more than you should.
Old Sep 26, 2002 | 02:01 PM
layjzay's Avatar
presently using 10w40 yamalube.
It does not take very much clutch useage to make this happen. I have taken the clutches out a couple of times and they are not burnt. The last time I took them out I replaced them with some from EBC and it still does the same thing.
Old Sep 26, 2002 | 02:35 PM
Raptoryfn660r's Avatar
RIP Dear Friend
Use BP/Amoco 10w40. No problems with clutch. Never has had a smoke.
THEMOOSE,
Went to your web.
Nice looking Raptor. You have put some compounded money into it I see.
Chet
VP KNOWSALOT FACILITY
Old Sep 26, 2002 | 05:24 PM
THEMOOSE's Avatar
<< THEMOOSE,
Went to your web
Thanks!!
Yep &amp; the money just keeps compounding!! LOL!!
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
