Raptor Motor Rattling at high rpm
Old Sep 27, 2002 | 07:06 PM
wheeliedude's Avatar
I was just out on my raptor today, and noticed when i would rev it out (8000-9000rpm) the engine would make a loud, ringing kind of a rattle, sounding like it is coming from the top end of the motor. It still has normal power, and sounds perfectly normal upto a certian high rpm. Any ideas before I bring it to a dealer?
Old Sep 27, 2002 | 07:22 PM
JakalWarrior's Avatar
If its kind of a loud clatter then its your valve lash.
Old Sep 27, 2002 | 07:49 PM
VirginRider's Avatar
also check your upper motor mount, this was happening on my warrior and I found that the upper and lower motor mounts were losing up!
Old Sep 27, 2002 | 07:51 PM
2001raptor2001's Avatar
my upper steel motor mount broke and caused the bolt to rattle around
Old Sep 27, 2002 | 08:33 PM
RaptorRyan's Avatar
Check your valves!!!
Old Sep 27, 2002 | 08:49 PM
Thanks for the reply guys, I adjusted the valves in the middle of the summer, so they should be ok. I notice when I blip the throttle in nuetral, the carbs will move, so having them hit the pipe sounds possible, but I have the stock pipe. i'll check if everything is tight. I'll also check the motor mounts. Keep feeding me ideas, and if I fix it i'll let you know. thanks again.
Old Sep 27, 2002 | 10:57 PM
WarriorManiac's Avatar
The front springs on my warrior vibrate badly. Took me forever to find what was making the racket. Did it with the the factory shocks and now the works units. The skid plate also used to. I siliconed the frame clamps to fix them.
Old Sep 27, 2002 | 11:11 PM
yamahayzman's Avatar
i dont know too much about quad engines, but my friends rancher(utility) has a rev limiter, and i doubt that a raptor would have one, but on the rancher u can only rev then engine so much until it makes this kind of rattling sound........
Firefighter400
Oct 8, 2022 06:38 PM
ltrmc02
Jul 22, 2015 04:50 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
