warrior won't idle
Old Sep 30, 2002 | 01:47 PM
banshee4life's Avatar
my warrior won't idle it, also has great trouble starting. it starts when it is cold but not when it is hot. it is so hard to start the battery was dead after 10 starts. it has a an uni filter and a cobra pipe its a 1987. it won't idle if i let go of the throttle in neutral it will die right away. i need to fix that. please help
Old Sep 30, 2002 | 02:25 PM
WarriorManiac's Avatar
If it runs fine otherwise I would suspect the carb, particularly the idle circuit. Pull the carb apart and clean it well with good carb cleaner. Also go buy a can of compressed air check that all circuits are clear. Also be sure the air filter is clean and not overly saturated with oil.
Old Sep 30, 2002 | 06:41 PM
warrior350megamax's Avatar
also check the rubber boots connecting the carb and air filter, if it's cracked then that would make it very hard to start and not idle well.
Old Sep 30, 2002 | 06:51 PM
warrior007's Avatar
It could almost be anything from the idle set to low and air screw to the valves way out of adjustment.
Nosniborpapa
Sep 12, 2015 05:54 PM
Jaymc
Sep 11, 2015 07:45 AM
Minimod
Sep 10, 2015 09:20 PM
Hw00d
Sep 10, 2015 08:53 AM
Minimod
Sep 10, 2015 08:03 AM
