Locker on a Kodiak
Old Mar 27, 2000 | 05:37 PM
aby11's Avatar
I have been looking at the new Kodiak. I was wondering if you could put a locker on it and still be able to use the 2wd mode.
Old Mar 28, 2000 | 12:17 AM
Yammer_Hummer's Avatar
aby11,
The locker is a mechanical device to permanently "lock" the two front wheels to each other, eliminating the slip in the limited-slip differential. The limited slip design is a compromise that allows the two wheels to rotate at different rates when turning, resulting in easier steering.
The 2wd/4wd control will still work, as it is an electrically engaged servo. 2wd mode will still allow power to the rear only, but the front wheels will still be locked to each other. Steering will become more difficult whether you are in 2wd or 4wd.
In other posts including one today or yesterday for a Honda, you will see that many riders using lockers say you will get used to it.
Yammer_Hummer
shimanok2
Jan 29, 2016 07:37 PM
YankeeRebel
Oct 6, 2015 06:44 AM
stcspiderman
Sep 13, 2015 05:15 PM
Jul 28, 2015 12:12 PM
RedRancher
Jul 10, 2015 06:36 PM
