Odd rear hub question.
Here's my dilema. I have a 400EX and a Blaster. I can't stand the blaster, but it has brand new RAZR's on the stock wheels. My EX rear tires are shot. The problem is this... the wheels are a different size on the blaster so the tires won't fit my EX's wheels. And the blaster's wheels won't bolt up to the EX's hubs.
Does anyone know if blaster hubs will fit a stock EX axle?
Are the splines the same?
I know I can find out by trying it, but I just figured I would ask while I was looking around on here. Thanks guys.
The rear hubs are interchangeable. Thay are both 24 spline hubs. The back spacing on the Blaster is a little lower. Your should be able to get the axle nut on though. Do not try it without the washer if it does not fit. I have a 81 Honda Odyssey that I put Raptor rear hubs on.
I have never tried to swap the yamaha/ honda hubs. I do know that there is a company that offers a rear hub with interchangeable spline section so you can use the honda bolt pattern on yamaha axles. If the hubs interchange, why would this be needed? ITP makes double drilled wheels for honda/banshee, but I don't think they offer anything for honda/blaster. I think RPM makes the hubs I was talking about.
