Raptor starter problem - more help requested
Old Oct 21, 2002 | 03:16 PM
NotuRaptor2's Avatar
Default Raptor starter problem
Did a search and it is definitely the starter one-way assembly. Any one know which gears usually go bad along with this. There are two idler gears shown in the on-line parts finder. I would like to order what I need before tearing it apart.
5LP-15517-00-00 and 1VJ-15512-00-00.
My girlfriend has nicknamed my Raptor "1 Ride". You get to ride it once and then back to fixing it. I have to admit this Raptor takes more maintenance than the Kodiak and both 400exs combined. I like this one but definitely wouldn't buy another.
/Jon
Old Oct 22, 2002 | 03:12 AM
RichieRoadRash's Avatar
my bearing went out but my gears were fine. then after it was replaced my bolts sheared off. jeez.
Old Oct 22, 2002 | 08:42 AM
Thanks for the feedback. I guess I will pull it apart first. Hopefully the gears aren't ruined. I rode for a whole day with the starter messed up. I hate to think what else might have gotten damaged.
Thanks for the website address. It is tjpartsxpress.com
website link
/NotuRaptor
Old Oct 22, 2002 | 01:28 PM
garyc660R's Avatar
Probably nothing. You will HAVE too have the one-way assembly...this is all mine needed.
Old Oct 22, 2002 | 01:40 PM
bansheeman351's Avatar
Are these starter problems only on the 2001 models. Or are they on all of them.
Old Oct 22, 2002 | 03:13 PM
I thought it was only the 2001s that had that problem. Didnt they up grade the one way bearing assembly for 2002.
Old Oct 23, 2002 | 02:07 AM
not at all. the dealer here says that 99% of the raptors he has sold since he's been open have all come back for that very thing...01' and so on.
Old Oct 23, 2002 | 02:11 AM
oh yeah...CHANGE YOUR OIL AFTERWARDS. you'll see what i mean.
Old Oct 23, 2002 | 03:45 PM
Well, I just pulled it all apart and I am lucky. No metal shavings in the case and all the gears look perfect.
I plan to order the one-way and gaskets as soon as I am done typing this.
I will adjust the carb too. I read enough doing a search on this topic that I am worried that I am running a little lean. I hear some popping when slowing down most of the time. I guess the dealer didn't get it adjusted right after I installed the exhaust and opened on the airbox.
Thanks again for all the help.
/NotuRaptor
Old Oct 23, 2002 | 06:45 PM
Spoke too soon. How do you get the bolt off that holds the flywheel? I can't stop it from spinning. I don't want to buy the sheave tool if possible.
I tried putting it in gear and holding the brakes. Still couldn't get it loose. Is it a lefty loosee type of bolt?
/NotuRaptor
