Raptor starter problem - more help requested
Old Oct 24, 2002 | 03:18 PM
NotuRaptor2's Avatar
Default Raptor starter problem - more help requested
Need a little more help from those who have replaced the one-way bearing.
How did you hold the flywheel while you loosened the nut?
/Jon
Old Oct 24, 2002 | 03:26 PM
Ward660R's Avatar
I know this is going to sound out there but I have used an old leather belt to hold fly wheels and clutch baskets before. Just wrap it around the flywheel like it was your waist and wrap the other end around the foot peg. Hope I helped.
Old Oct 24, 2002 | 06:58 PM
bansheeman351's Avatar
I guess i shouldnt buy a 2003 raptor if there are still starter problems with them.
Old Oct 24, 2002 | 07:18 PM
garyc660R's Avatar
Jon, use an air gun and you will not have too hold anything. It will zip right off.
Old Oct 24, 2002 | 07:32 PM
  #15
raptorboy673's Avatar
when the one way goes out does it act like its just spinning itself, or skipping.
is there a perminent fix for it or is this going to be a yearly thing
Old Oct 24, 2002 | 07:49 PM
  #16
why doesnt yamaha fix this one way bearing problem so that i can buy another raptor in the spring.
Old Oct 25, 2002 | 09:31 AM
  #17
RaptorBoy673,
Yes if feels like it is spinning freely or spinning too long before catching. I've heard the problem stems from backfiring when trying to start your quad. Make sure your carbs are adjusted properly so you don't hear a popping from your exhaust when slowing down. Other than that, I don't think there is a fix per se.
I never worried about the problem as I felt it failing over the last 10 rides or so since I didn't realize the one-way bearing was inside the engine case. Next time, I won't wait so long to fix it when it starts going bad. I lucked out since my gears are all perfect. Many others have ended up with metal shavings in the engine due to the gears failing.
I have a huge number of hours on my quad and have had it almost two years now. I can live with this given the fun factor. I am way more upset of the tranny problem since I doubt this is a repair I will tackle on my own.
Thanks for the tips on getting the bolt off. I have an air compressor so I guess I might breakdown and buy the air tool if the leather belt trick doesn't work. Hopefully it does so I can properly torque the nut during reassembly.
It seems like a bendix solution would work better but I am sure the engineers have tested the amount for force that is generated on a backfire and realize that the bendix gear would get ripped apart.
/NotuRaptor
toonces
Oct 16, 2019 12:11 PM
AtvManiac78
Jul 11, 2015 03:20 AM
tweeder
Jul 5, 2015 01:57 PM
need4aquad
Feb 4, 2001 03:26 AM
RaptorGuy01
Oct 31, 2000 04:23 AM
