Problem with clutch
Old Oct 29, 2002 | 10:54 AM
Murph660R's Avatar
Default Problem with clutch
When I put on a new perch on my Raptor I had the same problem. The deal is that most aftermarket levers pull easier but not as far so all you probably have to do is loosen the adjustments down by the motor and adjust the slack out of the cable using the adjustment by the motor. This is the "coarse" adjustment. When you have this set right you can fine tune it with the perch adjustment. Hope this helps.
Old Oct 29, 2002 | 11:32 AM
Trixterboy's Avatar
I just went through this with my lt250r. My clutch started slipping at the dunes and when I got home I changed tires and rode it and it was really slipping bad. By the time it was all said and done I had replaced the basket,pressure plate and clutch only to find it still doing it. I found the tires on the back had no air whatsoever but they were hard enough they looked normal. The only way I found it was I saw a little black powder around the wheel.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Dec 10, 2002 | 02:13 PM
jessiejames's Avatar
Well I pulled it apart and one of the clutch plate got cocked in the basket and was stuck pretty bad.
Old Dec 10, 2002 | 02:31 PM
BlueLeader's Avatar
whatever you do, don't put Barnett clutch fibers in there. They are carbon fiber or kevlar and when they wear, the fibers (sand like material) float aroun in your oil and will demo you motor. The Do a search for more info.
Old Dec 10, 2002 | 02:44 PM
  #15
I went with stock fibers and steels
skinnyr6
Aug 25, 2023 02:18 AM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
