Jet Size for 03 Rap
Old Oct 31, 2002 | 10:47 PM
BShep's Avatar
Default Jet Size for 03 Rap
Does anyone know what the stock jet size is for an '03 Raptor? The reason I ask if becuase I just paid a local dealership to re-jet it, and they put in 155/155 @27.5... and I'm wondering, isnt that the stock jet size? Did they screw me?
Thanks
Old Oct 31, 2002 | 10:54 PM
desracers's Avatar
Not really since the bike is lean when you buy it. that way to make the EPA happy that we are not pollute, my ****!! Also is the pipe stock? Stock jetting I believe at 144/146 somewhere in that range.
The dealer rejet for you then you might be in the ballpark. I wouldn't worry about it, go out and ride and see what you THINK of it!
Go out and have fun.
Old Nov 1, 2002 | 12:02 AM
BShep's Avatar
Big Gun Pipe, K&N Filter and I hope to have it set up to run without lid pretty soon,, and they actually jettted it to 155/150
Thanks Desracers
Old Nov 1, 2002 | 09:19 PM
Hiram's Avatar
The stock jets for the raptor are 140/145. (I got the info about the stock jet sizes from an article in Dirt Wheels Raptor pipe shoot out) I just installed a complete Yoshimura Comp. exhaust today and the instructions said if no air box mods were used to leave stock jets, but it doesnt run smooth from just above idle to 1/4 throttle. Should I rejet even if Yoshi said not to?, or is there some other adjustment needed?
Old Nov 1, 2002 | 10:45 PM
BShep's Avatar
Good question,.,., wish I had an answer.,.,.,[img]i/expressions/face-icon-small-frown.gif[/img]
Yoshi pipes are bad as hell,.,.,.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 1, 2002 | 11:08 PM
quic89's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img] try this ---- set your low speed mixture screws out to 3 turns out as a base point---play with them at bout a 1/4 turn per adjustment to smooth out your idle and improve your 0 to 1/4 throttle response--- if that helps but is still not good---go to your needle---raise the needle -- put the clip 1 step LOWER than what it is --readjust low speed mixture screws--maybe--bike is a little lean from the crate anyway---ya outta be close to good at least at around sea-level to 3000 feet
Old Nov 6, 2002 | 06:01 PM
raptor03's Avatar
Hey bro i put on a full yoshi system with a proflow kit and outerwear and it rips!!!!!!i went with a150/155
and 1 1/2 turns on the fuel mixture screw...2 holes in the airbox and a trimmed snorkel,There is a thin piece of rubber between your snorkel just trim it out so it's hollow,But when i ran without snorkel it diden't idle right...I tell you it was a big diffrence i have to learn how to ride it again,It's not to loud at idle but when you gas it it sound like thunder...
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
Chasso
Sep 19, 2015 03:06 AM
