Need Tips for Speeding up my Wolverine
Old Apr 1, 2000 | 08:07 AM
hunterjody's Avatar
I have a 95 Wolverine and it is totally stock. Can some of you Wolverine die hards share some of your "hop-up" tips? I am planning to get a new pipe. Which one can get me the most power with the least noise? What's the best air filter for the money? I am up for inner engine tips also. Any tips are appreciated. Thanks,
Jody Smith
Old Apr 1, 2000 | 05:15 PM
wolv99's Avatar
For a pipe look into the megamax2 its avery good pipe and increases poer throughout the powerband.a jetkit will increase your throttle response. then get a pro desighn filter kit to replace the stock setup. and run it with the airboxs off of you could vent it.or you could just get a K&N filter. then look into a high performance cam, piston kit and valve springs.racinga new carb will help too.highlifter sell a high performance kit and so does duncan racing. if you switch to, maybe 24" tires you will gain some more topend speed with not a whole lot of power loss. look into the maxxis sur tracs
Pehter
Oct 3, 2024 11:00 PM
exmotocrosser
Sep 26, 2015 08:18 AM
ReconBayou
Sep 23, 2015 02:41 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
cornermike
Sep 10, 2015 08:30 AM
