Flipping front Rims..IS IT SAFE..
Old Nov 15, 2002 | 01:17 PM
raptor03's Avatar
Default Flipping front Rims..IS IT SAFE..
Just wanted to know if anyone has had any problems with flipping front rims before and if it rides the same,Also if the brake is exposed to damage after that..
Old Nov 15, 2002 | 05:37 PM
raptor03's Avatar
I guess no ons flipped there rims..laters
Old Nov 15, 2002 | 05:38 PM
YFZRacer's Avatar
i'm not sure if you can do it put watch out for the valve stems if you try
Old Nov 15, 2002 | 05:39 PM
YFZRacer's Avatar
if you don't have the money to get new a-arms you could also get spacers if you don't do lots of jumping
Old Nov 15, 2002 | 05:40 PM
raptor03's Avatar
Flip the front and put spacers on the back ,that's what i want to do..
Old Nov 15, 2002 | 06:02 PM
JakalWarrior's Avatar
Would be cheaper to flip the rears and get spacers for the front. Rear dont require valve stem relocation. (if the rears are offset)
Flipping the fronts is a little dangerous because of the extra pressure on the streering, which probably goes for any widening of the front end other than lengthening the a arms.
Old Nov 15, 2002 | 06:09 PM
raptor03's Avatar
The rear were flipped already but i want to make sure it's ok to flip the fronts ,Thanks Some more post will convince me..
Old Nov 16, 2002 | 12:25 AM
dfischer's Avatar
I don't own a raptor, so I can't speak about valve stem clearance. Have you checked that yet? In my experience w/other quads its usually a problem.
A reversed rim is really just more rim offset. That's just more load on the balljoints and etc... This will of course increase the twist and bumps you feel significantly, as there is a lot more leverage applied now. Add a steering stabalizer. Is it safe? Probably, if you can live with the bump steer, jolts and etc...
Look into the aftermarket for rims with more +offset. That effectively what a reversed rim does, and if the aftermarket makes one you can assume you front end is safe. Or, as nobody our there is claiming the front end is marginal, just do it.
STLyamwar
Jul 25, 2020 04:44 AM
cornermike
Jul 30, 2015 06:37 AM
carolinabomb
Jul 26, 2015 08:40 AM
black_thunder
Jul 9, 2015 05:58 PM
