Blinking 4x4 Light
Old Apr 3, 2000 | 12:11 AM
ryant's Avatar
I recently noticed the 4x4 light on my '00 Kodiak operates intermitently. It appears to be in the sensor that tells the 4x4 light to come on and not in the swith or light assembly itself. 4x4 still works when the light is out. If a "put the hammer down" the light will sometimes come on briefly.
The machine hasn't been in for it's first service & possibly this is something that can be adjusted?
Old Apr 3, 2000 | 06:39 AM
therock's Avatar
Let’s See Now,
You are the guy who has been brow beating the folks on this list and now you want some sincere advice. Hmmmm? I been noticing that you are fast to make fun of or smart off to people across the entire ATV forum. And I’m sure you’re drunken like juvenile whit is soon to follow this post. If in your opinion, you believe a question to be stupid, you take it upon yourself to hammer the poor soul. So now I see you want some help.
The only Stupid question is one not asked.
Old Apr 3, 2000 | 01:11 PM
ryant's Avatar
I repented and offered apologies now I am looking for some advice. What has happened happened. If you dwell in what has happened and throw it in someone elses face you are no better then them.
Old Apr 3, 2000 | 06:22 PM
95TimberWolf's Avatar
hmmmmmm, should i give him my advice. sure for once i think i can help someone. check the wiring from the switch or sensor all of the way up to the light and check to see if it has shorted out anywhere or there is any loose connections. i hope my advice helps u out.
95TimberWolf
______________________
95 Timberwolf 2Wd
Old Apr 3, 2000 | 10:44 PM
therock's Avatar
OK,
I did not see the repents.
If the earlier post don't help look for water inside the button housing. Or the bulb may be going bad. Also you may want to look at the connection at the servo motor on the differenntial,
Old Apr 4, 2000 | 03:23 AM
ryant's Avatar
The switch works and all the wiring checks. It must be in whatever tells the light to come on (the button doesn't turn the light on, something in the 4x4 engagement mechanism itself does). It's weird. If I puch the throttle the light will come on bright until I let off then it is either dim or off.
I have to take it for it's first service tommorow. I'll post what they say the problem is.
therock,
you have played with the jetting, I was wondering what is the average elevation where you are?
Old Apr 4, 2000 | 03:31 PM
The way it sounds to me u have a wire rubbing on the frame somewhere. or it could be somthing in the servo motor system. my guess is u have a wire or a loose connection somewhere. Hope that helps u out!
Old Apr 5, 2000 | 12:27 AM
ryant's Avatar
Got the scoop from yamaha today. There is a proximity sensor/switch that detects when the servo engages 4x4. It is the source of the problem. It is either defective or has become loose in it's mount.
speedbuff
13
Nov 11, 2020 10:16 AM
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Alex G.
Sep 16, 2015 12:13 PM
Steeldon
Sep 9, 2015 09:38 AM
