raptor pipes?
Old Dec 8, 2002 | 03:20 PM
  #21
Spectre's Avatar
Default raptor pipes?
Remove the Snorkle & lid, go 160 left / 165 right carb on your jets.
The main jet on your right carb is 5 larger than your left. So keep that in mind when you switch.
While the carbs are out, turn your air fuel screw all the in until they are seated. Be sure to count how many turns it takes until it seats. Do that on both carbs before you make any adjustments to see what the factory offsets were and use that difference in your final offset settings. THe right carb will be set richer because it's feeding two intake ports.
Don't adjust the needles right away, they may be OK. Ride it and see if you have any hesitation or sputtering.
Do a plug check and go from there.
Old Dec 8, 2002 | 03:22 PM
  #22
Spectre's Avatar
Yoshimura Comp. RS-3
Old Dec 8, 2002 | 04:14 PM
  #23
AlaskaYFM's Avatar
Adam, the only complaints against the CT or Graydon pipe kits are the noise levels... besides that, they do their jobs, and they do them very well...
Old Dec 8, 2002 | 08:40 PM
  #24
FastYellow650's Avatar
have any of you tried the full exhaust from mbrp it looks pretty cool on their web site (http://www.mbrp.com/atv/) the bends coming out of the head seem to be a rounder design then stocks head pipes, and for the noise lever its only a 93 dbl
Old Dec 14, 2002 | 10:07 PM
  #25
blackdevil's Avatar
(yamah raptor)i have a white brothers e seriers slip on i was wondering if its possible to have a head pipe with that..which kinds
Old Dec 14, 2002 | 11:12 PM
  #26
PatsRaptor's Avatar
I have trie a lot of pipe systems betweet my 440EX and now my raptor I think the FMF puts out the LEAST hp out of any of them
Old Dec 14, 2002 | 11:15 PM
  #27
BShep's Avatar
I went with the Big Gun Race Series complete . It is louddddd!!!! I noticed a huge difference on the bike when I put it on. And the head pipe is way fatter than the stock head pipe. I wanted the loudest I could get. But thats my money. Looks like e1 else is saying your best bet is with Yoshi or CT/Graydon. Whatever you choose Im sure it will work out fine. Good luck and have fun!
Old Dec 15, 2002 | 03:19 PM
  #28
RSO660R's Avatar
Duncan Racing is top notch but here in Oregon we have strict rules on noise pollution
and the Duncan is way to loud for around here .
Old Dec 15, 2002 | 03:58 PM
  #29
Ward660R's Avatar
And have you priced the Duncan? I would like to try one but not for $600.
Old Dec 15, 2002 | 04:15 PM
  #30
rideraptor420's Avatar
i have an fmf header with white brothers exhaust it it rips
