Banshee shock settings
Old Nov 27, 2002 | 07:23 PM
RIDEORDIEYZF's Avatar
Default Banshee shock settings
How do you guys set up your STOCK yamaha banshee shocks? I want to know because everytime i get on someone else's banshee theirs seems to be much smoother than mine. Could this be a difference between j-arms and a-arms? (because my banshee has j-arms and the others i've ridden have a-arms)
I usually set mine up with the frount and rear soft but not all the way soft.
How do you guys do it?
BTW i ride dunes and jump alot.
Thanks
Old Nov 27, 2002 | 07:42 PM
YFZRacer's Avatar
ya i think if should go stiffer on my front shocks also i only weigh 110 and when we got it we put it on the softest settings but i think if should go stiffer how much stiffer to you think if should go i don't do any huge jumps or mx lots but i like catching a little air and it seems to be bottoming out a lot (i know the shocks suck but maby i can make them a little better)
Old Nov 27, 2002 | 08:11 PM
Peltrax's Avatar
I dont bottom my fronts on my blaster just the back,so i tightened it only,its all the way tight ,and the fronts are on the 2nd setting from soft......On your banshee the problem is the j-arms,they suck,ive had a atv with them and it rode so unbieliebly rough,good thing is they make conversion kits to turn it into a aarm front end.
Old Nov 27, 2002 | 09:23 PM
YFZRacer's Avatar
lol i didn't know you could even adjust the back how do you adjust it wow you learn something new everday
ya it would probably have something to do with the whole jarm thing
fd24
Jan 16, 2019 08:59 AM
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
greg74
Sep 10, 2015 07:58 AM
