warrior exhaust red hot!!!!!!
Old Nov 27, 2002 | 07:48 PM
paintblaster41's Avatar
Default warrior exhaust red hot!!!!!!
ive been having troubles w/ my warrior lately, it starts up fine first thing but then when i ride for awhile it stalls. then it wont start after this happens a couple of times. I tore the carb. apart and it was clean put it back in and it didnt start at first. Finally it started, but its only 22 outside,I let it run for about five min. the exhaust was red hot coming out of the engine were it bolts on the head. Whats wrong?
Old Nov 27, 2002 | 08:10 PM
JakalWarrior's Avatar
See if ur plug is gapped right, see if your carb and intake tract is all leak free. All I can think off without seeing it.
Old Nov 27, 2002 | 09:05 PM
RIDEORDIEYZF's Avatar
Check your topend gaskets, if one is blown out then it will run really lean and get hot. Thats what happened to one of my old dirtbikes, i am not sure about a warrior though.
Old Nov 28, 2002 | 08:50 PM
RaceWarrior350's Avatar
I bet ur carb boot is cracked or broken and its letting air leak making it run really lean causing it to get hot, ive broken mine like 4 times it sucks.
Old Nov 29, 2002 | 01:58 AM
WarriorMadness's Avatar
Sure sounds aweful lean to me, Id check that intake boot,and all the gaskets on the topend. Also does your airbox have any mods to it, if so the cold weather could be causing it to go lean. If you have holes in it then tape them off and see how it does. Just a few thoughts......
<U>ULTIMATE WARRIORS</U>
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
