Warrior Can't Climb
When I approach a long hill my motor won't rev and I quickly lose powerand sometimes stall. Is this because of the high altitude that I ride in or is this common on warriors. Any suggestions would help.
Santa,
Unfortunatly I can't tell you what your problem is, but I can say that my buddy has a Warrior and it does not have that problem. As long as you are downshifting as needed it should be able to climb just fine.
-Josh
-Josh
Na man cant help u here, my warrior pulls great up hills and i can upshift if i get it reved out on a long one, never had that problem, sounds like maybe air fuel screw may be off, seems like ur losing power, check the carb boot and the clean the carb and tune it in.
EsHe
EsHe
Well first off my Warrior can climb just fine up hills. Secondly we need a little more info than your Warrior won't climb like have you modified it in anyway? Has it been like this for awhile? Have you changed something that would affect its performance?
