New Wolverine
Howdy to all y'all out there. I just bought a 2000 Wolverine and was wondering if any of you could give me some sugestions as to what performance up-grades i can do to it. Mainly based on what y'all have done to your atv. Thank You Much.
As you can see by the list of mods at the bottom of this reply, my bike is far from stock now. But it was when I bought it other than the 25" tires which are a must for ground clearance and also top speed too.If your bike is totally stock the first and best money spent would be to get a good aftermarket exhaust. The stock one is too restrictive and doesnt breathe enough especially if you plan to do other mods in the future. I as well as a lot of other people like the FMF pipe. It sounds good as well as it raises the torque a lot if you run it with the 11 discs installed on it.It also looks good too. I would also get a better air filter and possibly a better filter mount too like a pro flo adapter or something similar. the stock setup is poor and will let dirt in past the rubber seal where the filter meets the airbox. I made my own
similar to a pro flow. Some other mods would to get a jet kit and maybe vent the airbox also cause this helps a lot and is cheap to do.The list is really endless.
Depending on what results you want? If your looking to make it faster put bigger tires on it. This will slay your bottom end. Its kind of a trade off though. I have left my stock tires on. And done the following and enjoy it alot! I have replaced the air filter (I agree with the other whom recommended this) Only I used a UNI filter. I used a SuperTrapp pipe with the disc system. Did some custom jetting. And I rather enjoy it! With the stock tires this thing is REALLY spunky all through the power band. I havent gone as extreme as the other person who replied but I found these mods to be very pleasing! Hope I helped some.
'99 Wolverine UFO handguards, UNI filter, SuperTrapp pipe, Custom Jetting, Skidplate
'00 Warrior Skidplate+Bumper
