Plug heat range
Old Dec 9, 2002 | 04:09 PM
LOWBOWTIE's Avatar
Default Plug heat range
What heat range of spark plug are any of you using on a Raptor with 11:1 piston? I know on cars we use a colder plug with higher compression. Right now it has the stock style plug. If any replies please give the NGK # .
Thanks
Old Dec 9, 2002 | 04:53 PM
LOWBOWTIE's Avatar
Come on , you guys are pro's at this stuff by now.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 9, 2002 | 06:43 PM
AlkyBurninX's Avatar
For a little ATV engine, 11:1 isn't really that high. I wouldn't go any hotter than a 7 (NGK) or cooler than a 9. I would go with probably 8 or 9.
Old Dec 9, 2002 | 07:04 PM
LOWBOWTIE's Avatar
Thanks ALKy, It's a stock plug that has #9 in the part # so I'll assume that it all good.I thought the higher the number the hotter the plug and vice versa, correct me if Im wrong.
Old Dec 10, 2002 | 04:10 PM
The lower the number the hotter the plug. It has to do with the length and diameter of the electrode and how long it take the spark to travel through it. If stock is a 9, that is what I would run. An 8 should also run fine.
STLyamwar
Jul 25, 2020 04:44 AM
hugemoth
Jul 20, 2020 03:28 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
cornermike
Jul 30, 2015 06:37 AM
Captjay
Jul 23, 2015 12:33 PM
