need raptor help
Old Dec 23, 2002 | 01:30 AM
ew660r's Avatar
Default need raptor help
I hust ordered a kit for my new raptor. It had white bros, e-series, pro flo airbox kit and a jet kit.
How can i find out if the jetting will be correct?
Old Dec 23, 2002 | 02:11 AM
kyraptor23's Avatar
From what I gather, do a plug test. Or depending on how the raptor runs after installing the jets. Do a search on here, there has been tons of info posted on what you need.
Old Dec 23, 2002 | 02:14 AM
ew660r's Avatar
thanks, i figured since they came together from parts direct it would be the correct jets
Old Dec 23, 2002 | 02:17 AM
ew660r's Avatar
i think it was a dyno jet kit
Old Dec 23, 2002 | 03:00 AM
BlueLeader's Avatar
with that setup I believe the dynojet instructions say to use 146/148 mains, needle in 4th groove, air screws out 3 turns, for sea level.
I had the same setup and ran with no lid and then played with the e-series disc system to fine tune. I added 4 more discs to lean it out it was perfect.
if you are lean with the lid off, put it back on to richen it up.
if it is rich with 12 discs, add more to lean it out.
hope this helps.
Old Dec 23, 2002 | 03:09 AM
ew660r's Avatar
thanks that should help. I trail ride alot.
Old Dec 23, 2002 | 03:10 AM
ew660r's Avatar
I'm new here. How do i change the pic to the left?
Old Dec 23, 2002 | 03:13 AM
BlueLeader's Avatar
click on profile at the top of the page.
Old Dec 23, 2002 | 03:59 AM
ew660r's Avatar
thanks
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
