Hole in Banshee Case
Old Dec 23, 2002 | 03:27 PM
hak231's Avatar
Default Hole in Banshee Case
Hello all! I was wondering if any of you Banshee Tech wizards can help me out with question I have? I just purchased a used Banshee and when I removed the engine, I noticed a hole in the lower case. The hole is about a 1/4" around and is located in the deepest recessed area of the case. Question is, Is this a place of the case where no oil circulates? Are there any internal components in this area. Reason I am asking is because it seems as if no oil has leaked out, whole area has no dirt or grease near it, it's all clean. The transmission is not locked-up and doesn't make any funky sounds. I hope you understand what area of the case I am speaking of? It looks almost as if the bottom of the case meets the top, thats how deep this recessed area looks. Is it going to hurt anything? Can I just clean it up and put some JB Weld in there? This is where there is a hole
I think the hole is inside here
If anyone can give me some insight on what to do, it would be greatly appreciated. Thanks!
Old Dec 23, 2002 | 06:34 PM
AlkyBurninX's Avatar
DON"T WELD IT!!!!! That hole should go all the way through to the top. It lets dirt, gas, water, etc fall instead of getting stuck below the carbs.
Old Dec 23, 2002 | 06:37 PM
hak231's Avatar
So what you are saying is that the hole is supposed to be there? Wouldn't that prevent the vaccum for the intake?
Old Dec 24, 2002 | 07:46 AM
hak231's Avatar
Any one else have a clue about this?
Old Dec 24, 2002 | 10:25 AM
WyoDuner's Avatar
Alky is correct. That lets stuff fall through instead of accumulating on top of the case. You can tell that hole is supposed to be there right??? Its smooth and machined.
Old Dec 24, 2002 | 07:51 PM
hak231's Avatar
No, the hole is not smoothed and machined! It is not the same hole as highlighted in the 2nd pic. The 2nd pic just shows where the hole would come to. The hole is in the underside of the lower case, as seen in pic one. I think that the area is hollow and would come all the way up to the highlighted area in the 2nd pic . Understand??? Maybe I will take a pic of it this week to get confirmation that it is allright.
Old Dec 25, 2002 | 05:01 PM
WyoDuner's Avatar
OK, I get what you're saying. Still as long as it doesn't go into the engine from the outside you should be fine. It's not as if it was made from a rock or something and jagged right???
Old Dec 25, 2002 | 07:36 PM
hak231's Avatar
No, the hole isn't that big. But how am I to be sure that it doesn't go into the crankcase or tranny without splitting the cases? The idea that it still holds oil and doesn't spew fluid anywhere leads me to believe that the hole goes into an area that contains no internal components or oil. But does the lower case really have hollow spaces like this? And if everything is allright, shouldn't I still JB Weld it to protect it slightly?
Old Dec 26, 2002 | 10:19 AM
WyoDuner's Avatar
Ok, I guess the pics weren't of your cases since you said you don't want to split the cases. Do this; below the carbs, on top of the case you will see the hole(s) below the carbs. Stick a wire or something flexible down that hole(s) and see if the wire comes out where you are seeing the hole on the bottom. I'm sure this is the same hole you're talking about but I'm not inclined to jack up my Banshee to check it for you. [img]i/expressions/face-icon-small-smile.gif[/img]
I'm sure it's perfectly fine and made that way.
Old Dec 28, 2002 | 05:49 PM
hak231's Avatar
Well thanks fellas! Looks like you were right from the beginning. I took a coat-hanger and ran it into the hole, it just kept going through. I flipped the engine back over and saw the wire coming through the hole below the intake manifolds. It turns out that the "cleansing" hole was hit by a rock or something and just made the opening jagged and beveled. Thanks for you help AlkyBurninX and WyoDuner. Your knowledge and expertise has been greatly appreciated!!!
EIF
Apr 20, 2017 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
2many2ride
Sep 27, 2015 04:35 AM
WilliamBos
Sep 22, 2015 04:07 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
