Air box help
Old Dec 28, 2002 | 12:50 AM
Starky's Avatar
Default Air box help
What do you guys do with the engine breather tube when you remove your airbox lid and snorkle. I just replaced my stock filter with a GYT-R foam and a 14min adaptor plate but I don't want to run it without the lid because the breather tube will be open to outside air.
I'm sure there is a simple solution, I just don't know what it is.
Old Dec 28, 2002 | 12:57 AM
RaptorRacer1's Avatar
Get a little K+N or foam filter that will clamp onto that tube (probably 1/2" inside diameter). You can find them at an auto parts store or catalog (Summit Racing) or in most all ATV parts catalogs (parts unlimited, JL, etc.). Unless you ride in really messy conditions it is probably not a huge problem even leaving it open, because I don't think it pulls in any air at all. Hope that helps!
Old Dec 28, 2002 | 01:06 AM
Starky's Avatar
RR1, Every little bit of info helps. I don't want to take any chances with the 01 Raptor. I'll look for one of those little filters.
Old Dec 28, 2002 | 03:06 PM
Ernie660R's Avatar
I don't run a air box lid either, I left the crank case breather tube open and do not have any problems, but i do not ride in any area where water can get to it. Summit sells a K&N filter that will work great.
Old Dec 28, 2002 | 03:17 PM
XtremeRaptor's Avatar
I went to the auto parts store and bought a small crankcase breather and attatched it to the hose using the factory snorkel "nipple" and the clamp provided with the filter. These filters are usually found in the "high performance" section of auto parts stores. Hope this helps you!!!
Old Dec 28, 2002 | 03:22 PM
GregV's Avatar
Mine has been hangin' and I haven't had any problems yet. I suppose a little filter of a swatch of foam zip tied around the hose woud probably be a good idea. I may have to look into that.
Old Dec 28, 2002 | 03:23 PM
Ernie660R's Avatar
Say extremraptor, what part of west texas do you live, I live about 20miles south of houston texas.
Old Dec 28, 2002 | 07:38 PM
Ward660R's Avatar
Yep, I have a little crank case breather on mine too. $10 at Auto Zone, its even black to match, in the import car section.
Old Dec 28, 2002 | 09:04 PM
Starky's Avatar
I knew it was simple, thanks a lot.
Old Dec 28, 2002 | 10:53 PM
sixsixT's Avatar
Starky check out the pics of mine in the gallery or my page what ever it is. Also do a search type in "breather"
