Extended swingarms and a-arms on a blaster?
Old Jan 2, 2003 | 04:10 PM
2001atv's Avatar
Default Extended swingarms and a-arms on a blaster?
I would like to lengthen and wider the Blaster and was wondering what is the best route? I did a search on E-bay for a longer swingarm and found a +4 that was $100 but it came unfinished. Anyone made there Blaster more stable without spending a $1000?
Old Jan 2, 2003 | 04:33 PM
BLASTERDEVIL2's Avatar
no but if you find out please let me know
Old Jan 2, 2003 | 04:38 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
To do it right.............nope!!!
The problem is,,,once you stretch it, then you need to spring it,,,then you need to make it more powerful. Unless you dont mind your front tires never leaving the ground.
Old Jan 2, 2003 | 04:41 PM
2001atv's Avatar
I know Trenga will lengthen the stock swing arm by 3" for $300 but then the back brake won't work so you have to buy there brake kit and a new chain.
Old Jan 2, 2003 | 04:43 PM
Bing's Avatar
Super Quad Patrol
Yup, that too.
I have installed a 3 1/2 " (i think) extension.
The chain adjusters are a pain also.
Old Jan 2, 2003 | 05:00 PM
1badblaster's Avatar
i put a lonestar axle in and got swingarm extended by ATV RACING (their ad is in dirtwheels) and u can get a-arms extended by sre
axle 395
swingarm 295
extend a-arms 300
total 990
so yes u can make it stable for under 1000
Old Jan 2, 2003 | 05:16 PM
YFZRacer's Avatar
you can flip the front tires thats free and spacers and extentions if your not doing lots of jumping
Old Jan 3, 2003 | 08:48 AM
2001atv's Avatar
I sold my warrior and was going to try and get buy with the blaster for this summer and then get a Raptor or LTZ400 next summer. I guess I'll just ride it as it is and save for next summer.
Old Jan 3, 2003 | 09:45 AM
4strokekilla's Avatar
World class atv sells extended swing arms for 325 unfinished, Burgards +2/+1 a-arms off ebay for 425 and You could buy a used banshee rear axle, which fits a blaster and is at least three inches wider, Plus I've seen durablue axles priced as low as 249.
Old Jan 3, 2003 | 03:21 PM
Peltrax's Avatar
has anyone tried the Lrd blaster revalve/spring on the rear shock???It is 400 dollars and gives it 9 inches of travel and rebound adjustments....ITs cheaper than the 500 $ works steeler and i think it would work better
