Blaster Adjusting Rear Shock
Old Jan 7, 2003 | 04:17 PM
PropXprt's Avatar
Default Blaster Adjusting Rear Shock
I just bought a 98 blaster, I softened the front shocks up (i weigh 120lbs) and I am not sure how to soften the rear shock...if ya'll could help I'd really appreciate it...
Old Jan 8, 2003 | 11:40 PM
Blaster96's Avatar
You can not.... All you can do with the rear shock is play with the height of it. No spring dampers or tensoners.
Old Jan 9, 2003 | 12:40 AM
Blastermaster's Avatar
the spring should be adustable for pre load only there are two nuts somewhere on the shock body it has been a while since i sold my blaster so i cant really remember, just loosen the second nut and then loosen the first nut(the one closest t the spring) sorry i cant provide somebetter info but it has been awhile since i messed with mine and it is gone now so i have nothing to run look at but i hope that helps u some
Old Jan 9, 2003 | 12:45 AM
ok wait did some digging and found my old blaster owners manuel and hears what u gotta do
on thee bottom of the shock body there is two nuts lossen th eone on the bottom and then turn the one on the top untill u have ur preload the way u want it
basically the same thnig u did to the front but iy is a thredid adjuster instead of a notched one
Old Jan 10, 2003 | 02:16 AM
PropXprt's Avatar
thanks ya'll
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
07Redrider400
Jul 25, 2015 05:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
