Blaster Engine Studs
Old Jan 7, 2003 | 11:40 PM
WarriorMan05's Avatar
Default Blaster Engine Studs
Okay, we blew a head gasket on my 99 Blaster. Take the engine out
Old Jan 7, 2003 | 11:43 PM
and i start trying to take the head off. I get one off without any problem, and start trying to get the opposite side loose. It is really really hard, and it starts coming a little bit, but it is squeaking and I think I might be pulling out the engine stud that holds it on. What should I do to prevent this from happening, or what will happen if they do come out? Do they just go right back in, or what?
Thanks for all the help,
Josh
Old Jan 8, 2003 | 11:25 PM
Blaster96's Avatar
They are screw in type. Once it comes out, it will be hard to get that nut off, so you will need to buy a new stud and nut. Some lock-tite should hold the new stud in just fine. Also refering to a service manual might help too.
Old Jan 9, 2003 | 12:23 AM
Okay, but I learned that I have to take it into the shop, to break the case. How much should this cost? and does it have to be put back on by them, or can I do it? I want to do all the other work to it, but I may just have them do the work that I want done, which would be a High compression piston, and maybe a new carb, if I cant do it myself.
Thanks for any help
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Frisky2050
Apr 9, 2020 11:19 AM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
joeyupton
Jul 14, 2015 11:51 AM
