55 gallons of race fuel in Gilbert AZ???
Contact:
KD Cycle - KD Enterprises
2431 E. 16th Street phone: (928) 329-1908
Yuma, AZ fax: (928) 329-1970
85365
info@kdcycle.com
They should know who in Yuma has race gas...
or
http://www.sellerspetroleum.com/76Lubricants.htm
Yuma is a very convienient stop on the way to the dunes, I'm sure you can arrange to swing by and grab a drum !
85365
info@kdcycle.com
or
14 mins, if you are coming in from tx you shouldn't be going through phoenix.(unless you are picking someone up). anyways you can also pick up 55 gal drums of trick or alchohol in tucson at . Flint Oil its right off the freeway - yes we only have one freeway.
If you are coming to FSW you can get fuel in El centro. They sell 76 110 at the pump for 4.15 a gallon or if you buy a drum i think it goes down to 4.00 and under a gallon. And another fuel station just opened up a pump that has 111, not sure of the price. you can buy the 5 gallon jugs of trick and vp in brawley and el centro but they are like 30-36.00
76- seller petroleum
350 w aten rd
imperial ca. 92251
760-355-7900
350 w aten rd
imperial ca. 92251
760-355-7900
You can buy it by the drum at the Goodyear/Turbo RX Store at Chandler Blvd. and Kyrene in Chandler. Their phone number is (480) 893-7722. They sell most Sunoco products.
However, the cheapest place, and they will deliver a drum to your home without a delivery charge, is a salvage yard near 25th Avenue and Broadway in Phoenix. I am not sure the name of the place, but their phone number is: (602) 276-9250. This is the vendor for most everyone in Phoenix that gets Sunoco products. They will also sell directly to the consumer regardless of the amount. This is where I get race gas for my heavily modded Banshee. I run Sunoco Purple.
The gas station that sells Trick fuel from the pump located near 44st and Chandler is almost always out of fuel. Besides, it is 101 octane unleaded. Not the right stuff for me!
MikeyBoyesq
08-10-2015 11:11 AM
