do i need a piston
Old Jan 12, 2003 | 03:48 PM
whitebread's Avatar
Default do i need a piston
in getting a stage 2 cam for more top end,do i really need a higher compression piston if all i do is race shorttrack,i dont believe i need to get to 5th gear faster,but i do need more speed out of my top end.
Old Jan 12, 2003 | 03:56 PM
truckracer's Avatar
Those bigger cams bleed cylinder pressure off (valve overlap). Hence the need for more compression at lower RPM's to compensate. Yes, you need more compression to make the cam work properly.
Old Jan 12, 2003 | 03:59 PM
whitebread's Avatar
thanks truck,wasnt real sure
Old Jan 12, 2003 | 07:16 PM
Ernie660R's Avatar
Whitebread you are running a standard bore 660 aren't you. If you are contact 14mins for a 11:1 JE piston, I think he has some in stock.[img]i/expressions/face-icon-small-smile.gif[/img]
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
