blaster air box and jetting
Old Jan 30, 2003 | 09:29 PM
blasterdude86's Avatar
Default blaster air box and jetting
so whats sould i do to it
Old Jan 30, 2003 | 09:32 PM
blastermaster288's Avatar
um.........when u take your plug out is the color on it dark or light? u could try going down one or a few jet sizes. ask around a lil for othe rpeoples opinions.
Old Feb 6, 2003 | 10:08 PM
i have a 01 blaster and i took the carb off and got me some carb cleaner and i cleaned it and put it back on and took it for a run and it ran for a while and now it dont have any power at all u can hit the gas and it runs like u just fired it up and took off i dont know what i did to it i put the carb back to gether right and the idle i a little screwy i just got it rebuilt not to long ago its just out of the break in time but i dont know what wrong can some one help me
Old Feb 7, 2003 | 12:25 AM
PropXprt's Avatar
did you actually take the carb apart? or did you just spray carb cleaner in it?
Old Feb 7, 2003 | 04:24 PM
  #15
i took the bowl off and the main then put it back together how it was
could it be the air\fuel mix. screw
i wouldnt think there would be any thing major with the motor it starts like the 2nd kick and it does idle pretty good i know i said it didnt but i got to thinking i does
Old Feb 7, 2003 | 05:10 PM
  #16
PropXprt's Avatar
chck ur compression man, my engine always fired on first or second kick....but i just checked the compression the other day and it was at like 37psi....so get a gauge and check it.....my piston ended up being nice and scored all up, could be the same for you.....its worth looking into before it seizes and more stuff goes with it
Old Feb 8, 2003 | 06:56 PM
  #17
I took off the breether cap and its runing good it wasnt getin enough air but i still think i need to mess with the fuel air mixture. im sure its a carb problem cause it done fine before i took it off but i cleaned the carb then i found it was the air cap but there when im in first just cuisin holding the gas in on spot it dies out and comes back and dies out but i kind of got that fixed with the air / fuel air mixture but wich way do u turn the screw to get more air
Old Feb 9, 2003 | 08:57 PM
  #18
Honda125Fourtrax's Avatar
its not something i would do take my air box lid off but if u do get a better filter than the stock and a pre filter and clean it offten
Old Feb 10, 2003 | 04:31 PM
  #19
i have a k&n air filter which way do u turn the fuel mix screw to get more air?
Old Feb 13, 2003 | 09:29 PM
  #20
