raptor reverse
Old Jan 16, 2003 | 11:32 PM
wolv99's Avatar
Default raptor reverse
hey, i resently took my raptor to the dealer for the first service. when i got it back, the reverse wouldnt engage until i let of the clutch. it would then pop and somtimes it grinds in and be all set bit it never did it till i took it to the dealer. whats the deal
oh yeah never buy bikes from reynold motorsports in maine[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jan 17, 2003 | 01:40 AM
mugsy's Avatar
I have had a similar problem with mine but without the poping and grinding. Mine usualy won't engage till I let of the clutch. I know that when I bought it new I did not have to let the clutch out.
Old Jan 17, 2003 | 04:23 AM
spacollie's Avatar
Sounds half assed normal to me except for the grinding.
Old Jan 17, 2003 | 05:46 AM
03RaptorLE's Avatar
i have the exact same problem, when i switch to reverse it will not engage until i let the clutch out. and it pop, i guess half into reverse, makes this loud grinding noise until i push the shifter down again while it is grinding. this usually doesn't seem to happen when i work the clutch while im warming the quad up tho.
Old Jan 17, 2003 | 10:23 AM
xbox74's Avatar
mine does the same thing !! anyone have a fix for this?
Old Jan 17, 2003 | 10:42 AM
warrior007's Avatar
It could be a couple of things, its somewhat normal though
The clutch sounds like its dragging, not disengaging enough, it may need a slight adjustment or worn. The clutch is a wet clutch and prone to act differently with different oil and at different temperature so you want to adjust it to where its right when the quad is fully warmed. The dealer may have adjusted it for you but not ridden it, he may have put a different oil in it also.
Old Jan 17, 2003 | 11:42 AM
Raptorx44's Avatar
Mine has done this as well but only when cold.
Old Jan 17, 2003 | 02:40 PM
Hiram's Avatar
Mines also does the same thing, reverse wont engage unless I keep the gear shifter pressed and release the clutch a bit. I also get a big pop when going into first gear none of this was so until about after 6-7 hours of use on my new quad, I thought it was normal breaking in and in the 10 hour service i would let techs know and it would be adjusted, but no luck dealer said it was normal and after arguing for two hours and asking them to explain why it didnt do it the first few hours they had no answer. So I will never take it back to them and deciced to buy a manual, I adjusted the clutch somewhat (its alot better but still not like new) I tried removing some slack from the the lever but that made it worse, but giving it slack to the point were its almost engage, (while holding the lever in).and checking by lifting the rear of the quad and adjusting to the point the wheels almost start to spin has helped it out on mines.The adjustment has left it to were if I just bearly release the lever it starts to engage. But the poping into 1st is noticable less......before it sounded like I was going to break something.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
