Raptor reverse Engagement, How To
Old Jan 24, 2003 | 12:17 AM
yamaha4life's Avatar
Default Raptor reverse Engagement, How To
talk about a surprise sitting at the line ready to go in 1st hit it shift and go backwards
might win 10 grand??
Old Jan 24, 2003 | 10:44 AM
warrior007's Avatar
Originally posted by: vdubn
Where is the spring, I can't see any springs on the lever down low on the engine. The switch itself springs back when you rotate it. Should there be a spring down on the engine?
Dean
If the lever springs back without the cable on it make sure the "travel" of the lever is the same with the cable on. The spring is behind the lever, if its hooked on the lever it should "coil up" when the lever is moved forward.
Old Jan 24, 2003 | 11:31 AM
vdubn's Avatar
Well, that explains alot, it appears that the spring isn't there at all.... it must have been lost when we disassembled the bike.
I'll try to locate it and see what happens. It sounds like its pretty straight forward as to how to put it on.
Thanks,
Dean
Minimod
Sep 10, 2015 09:20 PM
Steeldon
Sep 9, 2015 09:38 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
black_thunder
Sep 7, 2015 01:24 AM
Elkaholic
Sep 6, 2015 02:44 PM
