no help
Old Jan 24, 2003 | 03:01 PM
Inch's Avatar
Default no help
thanks, all you raptor fans. i need info on Kodiak 03. rev limitor removal..........
Old Jan 24, 2003 | 03:22 PM
AlkyBurninX's Avatar
Default no help
If someone knew, they would have replied to one of the first half-dozen threads you posted.
Old Jan 24, 2003 | 03:34 PM
Inch's Avatar
Default no help
blow me
Old Jan 24, 2003 | 03:35 PM
yamaha4life's Avatar
Default no help
snip the red wire....or is it the blue??
Old Jan 24, 2003 | 03:41 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default no help
No offense Inch, but you may want to give it a chance.
Check the thread tommorrow.
Use the search feature, it may have been covered already.
good luck
Default no help
Its red with a blue tracer[img]i/expressions/face-icon-small-smile.gif[/img].
Inch, easy with the language. There are some younger readers on here. Wait a minute, why am I telling you? You are obviously one of them.
Old Jan 24, 2003 | 04:00 PM
Default no help
hell cut all three of them it will work then
Old Jan 24, 2003 | 05:27 PM
NotuRaptor2's Avatar
Default no help
Can't help you with your question but...I hope your girlfriend didn't come up with your screen name...
Old Jan 24, 2003 | 07:15 PM
Default no help
HAHAHAHA LMFAO!!!!!!
Old Jan 24, 2003 | 10:53 PM
Linerider2's Avatar
Default no help
[img]i/expressions/face-icon-small-confused.gif[/img] Why can't you get a schematic for the cdi sytem, see which circiut was added on the 03 compared to the 02. When I was hot rodding outboard motors some you could simply unplug a connector to override the limiting device. Others you had to replace the cdi module with a non-limiting one. You will see the after market electronic guys fix this in the future for sure. Knowing yamaha this may be a shared circiut and may not be so simple, they may be picking up the signal to dump the scr switch and control rpm all in one circuit. Any how this gets very confusing without going into electronic theory and the like. So just ride hard, and know you won't blow the top off with the limiter in place. By the way stock is always more reliable.
