gearing a raptor
Old Feb 11, 2003 | 01:05 AM
sparkless's Avatar
Default gearing a raptor
i'm wondering if there are any proven sproket combinations , i'm sure most raptors have the same issue the gears , seem tobe short
but ,the question is do i gear it to be able to run 1st and 2nd longer , or gear it so 1st and 2nd are even shorter and use 3rd gear?
asumming i running up olds persay thanks for any imput!
Old Feb 11, 2003 | 01:18 AM
sparkless's Avatar
is that launching with stoke gears our with 12 tooth i launch 2nd and stay there till the race is over with stock gearing but it runs out of gear 3/4 hill
Old Feb 11, 2003 | 01:41 PM
RoostItUp's Avatar
You don't need a seriously high hp raptor to start in second. Make you gearing 12 on front and 43 on back, this freaking works great! I can start in second at the bottom of the hill and get into 4th by the top!! With that gearing I can beat ALL Raptors modded similar to mine! Trust me, give it a try! Good luck!!
Old Feb 11, 2003 | 02:32 PM
raptor03's Avatar
so your atleast going up in third,because it wants to go up in third but sometimes not enough power(Unless i get a running start),and second i cant get no more speed from it.andby the time im up the hill,going to a 12 tooth front and try that first then maybe go to the 43 rear.
Old Feb 11, 2003 | 04:06 PM
holeshot77's Avatar
I have no problem with going up olds in therd gear with a 12 tooth was thinking of maybe going back to stock just to see if i can get more speed, and i weigh 210#
Old Feb 11, 2003 | 04:15 PM
raptor03's Avatar
why third is not fast enough?or are you losing horses going up./.
Old Feb 11, 2003 | 04:16 PM
UBETRUN's Avatar
I'm with BigBubba, gear that sucker so you can use everything the motor's got. Unless you are after some sort of top speed record, the Raptor will try to rip your arms off with the higher numerical gearing. On a MX-style track, I believe acceleration far outweighs a few extra shifts here and there. We'll see for sure next month:-)
FWIW, a piped and jetted Banshee is the only machine I've gone against that can sometimes get the holeshot and if I only had 20 more feet....:-) Z400, 440EX, and DS650 don't even come close, they say my bike is brutal. Sliding through a 2nd gear turn is an incredible rush when the tires hook up and you freakin' LAUNCH!
Old Feb 11, 2003 | 04:19 PM
holeshot77's Avatar
no ihave plenty of horses pulling iwas thinking that when i go back to stock maybe a little fasterb but kont know if the motor will like that idea[img]i/expressions/face-icon-small-mad.gif[/img]
Old Feb 11, 2003 | 04:23 PM
UBETRUN's Avatar
Oops, sorry guys. I see that you are talking about dune riding. Don't know if my post helps the thread or not since I don't ride dunes (yet?). I imagine the same theory applies and you could gear your dune Raptor to keep accelerating all the way up the hill in 3rd.
Old Feb 11, 2003 | 04:24 PM
raptor03's Avatar
So should i get a better an bigger rear to go along with the 12 tooth front,like a 42 or 43,which one?
Should i try the 12 out first and then geta 42 or 43 rear...i ride sand and desert ,more hill climbing and wood runs..
