Reverse pinion removal
Old Feb 11, 2003 | 11:30 AM
BADBRONCO's Avatar
Default Reverse pinion removal
Can someone please tell me how the reverse gear pinion comes off the main axle on a Raptor? I'm in the process of upgrading to 02 gears nd I have every thing done except for the main axel. Thanks
Old Feb 11, 2003 | 12:37 PM
warrior007's Avatar
It has to be pressed off then the new one has to be pressed on. I am at the same exact stage and I dont have a press so I am going to take it to a local dealer or gas station. Makes it almost worth it to buy a new 5th pinion so you dont have to get at it.
Also make sure they leave .015" or .381mm gap between the 4th gear pinion and the main axle splines, its alot easier than measuring the entire assembly per the manual. The gap will allow the right amount of lubrication for 4th gear
Heres a picture of the measurement
Njrider1230
Jul 29, 2023 05:16 AM
Ean
Aug 20, 2015 07:13 AM
house1
Aug 9, 2015 10:49 PM
Schneider
Jul 24, 2015 05:05 PM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
