I need some simple help....
Old Feb 13, 2003 | 07:51 PM
Guest
Guest
Posts: n/a
Default I need some simple help....
Today i tried to examine my spark plugs to see if i was ok or not... I can get the one on the left cylinder out but the spark plug closest to the shifter and fuel pecock side i cannot remove. The reason i cant get it out is because i cant get the rubber spark plug wire off the top of the plug , the one on the other side just slips right on off and back on but the one on the right cylinder wont come off...is there a trick that i dont know about to remove it..is checking just one plug enough or do you need to check both..? i just want to make sure they are not white..also my coolent bottle that is on the back of the quad (behind the tool pouch) is empty ..do i top it off with water or coolent or 50/50? thanks
thanks
liquid sand
Old Feb 13, 2003 | 09:07 PM
fm1972nova's Avatar
Did you try wiggling the boot side to side? It just depends on what the weather is like most of the time i just mix mine 50/50 hope this help you. I'am sure the plug wire will come off you may have to take your airbox of so you got a little more room to work. GOOD LUCK.
Old Feb 13, 2003 | 09:44 PM
DaBeechMan's Avatar
It will come off, just keep moving it from side to side. YES you have to check both cylinder plugs. That is very important. 50/50 is a good percentage. The more coolant you run the hotter your motor will run. But 50/50 is a good ratio.
Old Feb 14, 2003 | 12:12 AM
THEMOOSE's Avatar
When your putting the boots back on this time put some waterproof grease on them this time & they'll come off easier next time.
Nosniborpapa
Sep 19, 2015 07:07 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Schneider
Jul 24, 2015 05:05 PM
Eaaicf
Jan 10, 2001 05:32 AM
