replacing banshee axel?
Old Feb 14, 2003 | 09:50 PM
RIDEORDIEYZF's Avatar
Default replacing banshee axel?
I am replacing my bent stock axel and puttin a dura blue +2 axel in. My problem is getting the axel out, i did exactly what the book told me to do and it wouldn't budge, then i heated up the thing that the sproket goes on and tryed to slam it off again. Am i dong somtin wrong because it will not move. Any suggestions? Thanks
Old Feb 15, 2003 | 07:30 AM
DaBeechMan's Avatar
If its stuck it might be a little difficult to get off. But it will come off. If it doesnt come off we'll get together out at our shop and we'll get it off for you. k?
Old Feb 15, 2003 | 05:02 PM
RoostItUp's Avatar
Ya, if it's been on there since '89 then it's prolly stuck pretty good. Just give it a good beating.
Old Feb 15, 2003 | 08:28 PM
I got it off. Took some slaming, but its off, man those bearings were shot, and the splines were all rusted.
Hey, Dabeechman thanks for the offer.
Old Feb 15, 2003 | 08:49 PM
AlkyBurninX's Avatar
When I built my TT bike about eight months ago, I switched the LSR axle that was in my playbike for the stocker in my now TT bike. I tried to take the axle out of my playbike the other night to change bearings. I worked for 2 hours just trying to get the axle nut off!!!! I had an 18" cresent wrench and couldn't budge it. I finally got it off about half an hour ago. It took a torch with a rose bud, the 18" cresent with a 7 foot long (no joke) cheater pipe, a 6 foot pipe to go between the swingarm and skid plate to keep the swingarm from lifting, a pipe to jamb in the sprocket to keep the axle from turning, me (310 lbs w/ lots of muscle) on the wrench/cheater, and my friend (365 lbs w/ muscle) on the 6 foot pipe. I still strained to get it loose. Just be glad you didn't have this problem.
Oh, by the way, my axle just slipped out though[img]i/expressions/face-icon-small-smile.gif[/img].
Old Feb 15, 2003 | 10:21 PM
Ya, i am glad i didn' thave that problem Alky. i wish my axel just slipped out!
Old Feb 16, 2003 | 12:19 PM
Holyman's Avatar
If you're reusing the stock carrier, make sure you drill it for a grease fitting. It costs about $1 in parts and will save you the headache of changing the bearings when they get water in 'em and they rust out. It will also make it easier ini case you happen to bend another axle [img]i/expressions/face-icon-small-sad.gif[/img]
Old Feb 17, 2003 | 11:33 AM
WyoDuner's Avatar
Also, make sure you grease EVERYTHING in there when you put it back together. I greased the spacer and splines for sprocket and brake disc even though they don't need to be lubricated but to keep them from corroding and sticking together. An ounce of prevention.....
Old Feb 17, 2003 | 02:11 PM
Why would yoiu put a zerk in if they are sealed bearings?
Cole Hadden
Jun 15, 2025 09:05 AM
JohnnySplat
Aug 6, 2015 12:07 PM
toonces
Jul 28, 2015 01:58 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
