Raptor connecting rod wear !?!
Old Feb 22, 2003 | 06:02 PM
FISHER1648's Avatar
Default Raptor connecting rod wear !?!
I'm in the process of stripping down the motor for a tranny conversion and noticed some unusual wear associated with the connecting rod.
1) There is some slight galling on the center section of the Piston pin and on the inside of the upper connecting rod hole. I'm surprised there is no bushing or bearng there. Is this OK - it's not sloppy and not blued.
2) The crankshaft has blued a bit at the lower connecting rod. It is not sloppy but I'm concerned it has not gotten oil real good.
Any advice is appreciated.
Thanks, Eric
Old Feb 22, 2003 | 06:58 PM
RacinJason's Avatar
My rod had very little discoloration when I rebuilt the trans, that may be a cause for concern if you are building your motor up. Had heard of a few rod failures but hadn't seen any yet.
BRAAAP
Old Feb 22, 2003 | 09:53 PM
Duramax's Avatar
Take it to a good machine shop for opinions. A reputable shop will not steer you wrong.
Old Feb 23, 2003 | 09:58 AM
warrior007's Avatar
Mine looks similar, I have seen other makes/models look similar also with no ill affects
byronman
Sep 6, 2015 06:34 PM
black_thunder
Sep 6, 2015 04:41 PM
toonces
Sep 5, 2015 01:14 PM
Aug 25, 2015 11:16 PM
black_thunder
Jul 9, 2015 05:58 PM
