Carb neddle battle
Old Feb 25, 2003 | 01:03 PM
TriRap's Avatar
Default Carb neddle battle
mikuni makes several diferent needles for those carbs but it takes vacuum to operate them and the more work you do to your motor the less vacuum you normally have at lower rpm's. That is what makes the fcr's so easy use. you are forcing the slide open with the throttle cable and not depending on vacuum. I did not want to spen the money either but after all the troubles I went through to jet my raptor it was so easy with the fcr's. It would be one of the first mods I did if I had to do it again.
Pipe and carbs right from the start!!!!
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
