swingarm opinons
Old 02-26-2003, 08:32 PM
yamaha4life's Avatar
Default swingarm opinons
seems like air has installed every type of product to rob h/p
next he'll put 25" realtors on the back
Old 02-27-2003, 12:50 AM
TriRap's Avatar
would someone explain how a double row of ball gearings could decrease horse power over tapered bearings. Even with two sets of bearings the surface area still much less than tapered bearings with no preload to speak of. How can that rob "HP"????
Old 02-27-2003, 09:01 AM
Ward660R's Avatar
He probably meant that it robbed him of HP switching from single row bearrings, which is what comes stock. I just want the tappered bearring because they will last longer, take better side load, and are easier to work with.
Old 02-27-2003, 09:31 AM
TriRap's Avatar
I will agree that they will take better side load but they are not easier to work with. The bearing is not sealed, you to set preload by tighten the axle nut. it is easy to burn the bearings by over tighten (then you will lose HP). If they are too lose you can destroy the carrier rip the seal and get the bearing full of sand, mud water, etc.. Even when you set it just wright you have the chance of the axle nut getting lose and destroying it all anyway.
I think I'll stick with my sealed bearings.
  #15
Old 02-27-2003, 09:37 AM
Ward660R's Avatar
You bring up a VERY good point. I never thought of that. I was actualy refering to ease of installation and removal. I do think your right, maybe I will go with a twin row set up.
  #16
Old 02-27-2003, 09:58 AM
eRAPTOID's Avatar
Hey Ward, what's up?
Yeah I've got a LoneStar Racing +3" swingarm. It's a very nice piece! Double row bearings in a round carrier. I don't know how much you're wanting to spend tho. It's pricey.
  #17
Old 02-27-2003, 10:58 AM
RaptorRyan's Avatar
I run an Eyeball +2, very well made & gussets at all the stress points.
  #18
Old 02-28-2003, 08:44 AM
Ward660R's Avatar
ERaptoid I think I have seen pictures of yours, right?
I wanted to do it for around $500-$600, I doubt I will be able to so....maybe if I find something on ebay.
Thanks for all the help.
  #19
Old 02-28-2003, 09:48 AM
BansheeMan98's Avatar
From What I have heard the Tucker is heavy as hell. You might want to check out the weight before ordering one.
Weight realy robs HP. jmo
BM98
STLyamwar
07-25-2020 04:44 AM
Quadzilla Heritage
09-25-2015 01:39 PM
95wolv
07-21-2015 12:25 PM
Dabears1983
06-23-2015 04:59 AM
Quick Reply: swingarm opinons
