raptor oil tank
raptor oil tank
Yes, Ive had oil leaking problems. First at the base of the part the oil line hooks to at the bottom of the tank. JB weld took care of that. Now its leaking at the flimsy joint where the two halves come together. [img]i/expressions/face-icon-small-sad.gif[/img] The CFM one on ebay can be had for $159.00 it's a good looking tank. Rockymountainatv.com has the UM oil tanks for $179.00. Comes with heat shield according to their picture. The ones with the holes are more. Don't know if they are nessessary or not. The stocker has no holes.
raptor oil tank
Like Big Daddy, I just bought the cfm oil tank off ebay. It fits perfectly and I can tell a difference after 1 ride. The clutch doesn't seem to fade anymore due to the extra cooling. The only concern though, is how close the tank comes to the steering shaft. This may pose a problem for a steering damper.
#15
raptor oil tank
Hey Raptordan.
I was just reading over this article at off-road.com, http://www.off-road.com/atv/projects/raptor2001/cfm/. They stated this: "Steering damper note: We have found the Denton steering stabilizer DOES fit with the larger oil tank and you could also use a bar mounted stabilizer like the GPR unit, but unfortunately the Hyper Pro damper will not fit."
I'll probably get one. The stock one is really a POS.
#16
#17
#18
#20
raptor oil tank
I don't recall a warranty issue but if thats the case then, yes, do as airraptor says. I didn't realise we were talking warranty. [img]i/expressions/face-icon-small-blush.gif[/img]
Damn, its right there in the first post. LOL maybe I need reading glasses. [img]i/expressions/face-icon-small-shocked.gif[/img]
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
