oil mix ratio
Old Mar 6, 2003 | 11:33 PM
hoede's Avatar
Default oil mix ratio
what is the ratio of a 92 blaster 250. also how can i tell if its a 250 or 125. its old but i can still see the vin?#
Old Mar 6, 2003 | 11:35 PM
Batoutahell's Avatar
I thought all blasters were 200's, actually like a 198cc.
I could be wrong. Also they are usually injected unless someone has used a block off plate in that case it depends on the oil you run. I run yamalube at 32:1 in my banshees.
Bat
Old Mar 7, 2003 | 12:45 AM
holeshot77's Avatar
All blasters are 200(198cc) unless a big bore has been installed
Old Jul 2, 2006 | 06:22 AM
gput02's Avatar
Old Jul 2, 2006 | 10:26 AM
Boomer2's Avatar
The injector pump injects the oil around 20 to 1 or 25 to 1. If the pump has been blocked off mix according to oil manufacturer. I mix Amsoil 50 to 1 in my 250r and Blaster
Cummins Driver
Sep 11, 2019 01:22 PM
Honski250r
Sep 26, 2015 09:40 PM
rockinkgin
Sep 25, 2015 01:52 PM
kdg723
Jul 25, 2015 01:20 PM
Fnqrider
May 31, 2015 08:29 AM
