guys please jetting problem !
Old Mar 9, 2003 | 12:55 AM
cOoLdevil's Avatar
Default guys please jetting problem !
hi all i have 2003 banshee and i install a trinity pipe with no airbox and K&N carb mount airfilter and i used a dynojet kit and i change the pilot jet to 27.5 and install main 280 and needle changed with dyno needles and its in clip #4 and im at see level and the humedety is letel high and i dont know what to make the air screw posetion so when i take the banshee out in the start i have to rev it high befor i releas the clutch and in 5th and 6th gear it takes long time to open the pretiors and when its open its real wekeed and i played with the air screw and i cant get it right so any help needed .
Old Mar 9, 2003 | 01:04 AM
2fun's Avatar
Dude!
You've TOTALLY confused me with that post![img]i/expressions/face-icon-small-confused.gif[/img]
How about some proper punctuation, and grammer?
Not trying to start another grammar flame, but damn![img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Mar 9, 2003 | 01:07 AM
RSO660R's Avatar
[img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 9, 2003 | 01:18 AM
Psycho's Avatar
[img]i/expressions/face-icon-small-confused.gif[/img]HUH????[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 9, 2003 | 01:20 AM
cOoLdevil's Avatar
can you guys leave my grammer a lone and try to help my with my problem ?
Old Mar 9, 2003 | 01:23 AM
2fun's Avatar
Not trying to pick on you, but........................
Thats my point!
I can't hardly even read the post![img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Mar 9, 2003 | 01:31 AM
cOoLdevil's Avatar
im sorry but i have a problem in me jetting so can you help me
i have 280 main and dynojet needle in clip #4 and pilot jet 27.5 and im at see level and i have the airfilters mout direct on the carbs
so how many turns should i use for the air screw
Old Mar 9, 2003 | 01:47 AM
2fun's Avatar
What mods do you have done to the Banshee?
What pipes, filter, timing advance, etc.?
Old Mar 9, 2003 | 01:50 AM
2fun's Avatar
You turn the air screw out till you get a crisp throttle response from off-idle.
If you have a hang-idle, you are too lean and need to either turn the air screw back in, or go to a larger pilot jet.
If you open up the air screw, and it still does not improve the throttle response, try going to a smaller pilot.
What do the plugs look like?
Have you done a proper plug check?
Read those plugs! They are a direct window as to what is going on inside the motor.
Old Mar 9, 2003 | 01:56 AM
cOoLdevil's Avatar
i only have trinity pipe stage 4 and K&N carb mount airfilter and im thinking to add boost bootle and i use ngk iredium plugs br8eix
