K&N or FOAM
Old Mar 9, 2003 | 09:09 PM
RaptorRy's Avatar
Default K&N or FOAM
I ride mostly in dusty or wet condition both ends of the extreme I will be gettting the prefilter airbox cover and will be making a couple of dune trips this year. your xperiance is greatly apreceited RY
Old Mar 9, 2003 | 09:10 PM
iamchad2k5's Avatar
Default K&N or FOAM
foam all the way. 1 reason. you can wash them, (if needed)
Old Mar 9, 2003 | 09:18 PM
Riznaptor's Avatar
Default K&N or FOAM
umm, you can wash K&N filters. But for dust mainly go foam. K&N will let some dust through becuase they let more air through. In sand K&N is the only way to go. Stops sand great, where foam filters get clogged with sand. You should have more than one filter. Maybe buy one of both.
Old Mar 9, 2003 | 09:21 PM
iamchad2k5's Avatar
Default K&N or FOAM
how could you wash a paper filter?
Old Mar 9, 2003 | 09:25 PM
wshrdskin's Avatar
Default K&N or FOAM
Its called K&N filter cleaner and water. Then use the K&N filter oil after it dries.
K&N with waterproof outerwear all the way, for any riding condition. imo
Better air flow, Very good air filter protection and way easier to clean, no mess no fuss.
Old Mar 9, 2003 | 09:29 PM
Raptor58's Avatar
Default K&N or FOAM
it's not paper it is made out of cotton guaze
Old Mar 9, 2003 | 10:24 PM
sixsixT's Avatar
Default K&N or FOAM
I agree with this.air filter?
Old Mar 9, 2003 | 10:29 PM
RSO660R's Avatar
Default K&N or FOAM
Originally posted by: Riznaptor
ugreat, where foam filters get clogged with sand. You should have more than one filter. Maybe buy one of both.
Okay im going to dissagree with you here I run NO AIR BOX and the foam filter and my filter never gets clogged I also run the outerware that came with it .
I will agree that oiling the filter kinda sucks but Its just another chore on the list like changing the oil.
Old Mar 10, 2003 | 12:10 AM
Lateralus's Avatar
Default K&N or FOAM
K & N Filter with Outerwear all the way. late,zubbeyboy
Old Mar 10, 2003 | 10:50 AM
WyoDuner's Avatar
Default K&N or FOAM
When it comes to real dusty conditions I guarantee that a foam filter will filter better than a K&N with or without outerwear. Foam doesn't flow as much air but it has a LOT more surface area to catch dust. K&N with outerwears are great for sand, foam without outerwear for dust is my preference.
