banshee motor help
Old Mar 10, 2003 | 01:40 AM
86250R's Avatar
Default banshee motor help
my buddy and i were out riding and all of a sudden his 02 shee started to back fire and miss fire out of the right side we have been doing all kinds of work on it and cant fix it we took of the carbs and cleaned them and replaced the reeds.and still no luck. we tried to kick it and try tunning it somemore and now its locked up and you cant kick it over. need all the info and help please have to go to glamis this weekend.
Old Mar 10, 2003 | 01:44 AM
Batoutahell's Avatar
Pull the head off and see what he has.
If its locked up that is not good.
Bat
Old Mar 10, 2003 | 11:30 AM
XxDumontRaptorxX's Avatar
Broken timing chain??? siezed piston???? broken valve??? Your answers will come with the removal of the head. Gl guys
Old Mar 10, 2003 | 12:16 PM
Ummmm, he is talking about at banshee, no timing chain, no valves........you must have thought he had a raptor.
Bat
Old Mar 10, 2003 | 06:04 PM
AlkyBurninX's Avatar
My guess is you will find the top of the piston is pecked up. I am guessing the crank bearing is shot. Pieces of the steel bearing can make their way to the topend and peck up the piston.
Its always the right side on a banshee just like #7 cylinder on a small block chevy.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 10, 2003 | 06:13 PM
desracers's Avatar
Try to take the pipe off and look into the exhaust . You should see if the piston is stuck there.... or just take the head off and see what you got there....
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
