Possible one way fix
Old Mar 10, 2003 | 12:47 PM
Blksnshn's Avatar
Default Possible one way fix
Hi guys I'm a new member and wanted to say Hi. Also I found this on another board it is a one way bearing fix for about 99 cents, here is the link. I am going to try this today if I can get the flywheel off, I will let you know how it works...
http://www.raptortranny.com/starter-o-ring.php
Old Mar 10, 2003 | 05:11 PM
warrior007's Avatar
Good luck with the o-ring, I am gonna try it in a few weeks myself. From what Grant says it sounds like the hot ticket.
Old Mar 10, 2003 | 05:39 PM
Raptoryfn660r's Avatar
RIP Dear Friend
You have some very good information there. Finally something is better on the 01.
The needle bearings. I have learned to start it in neutral and with the clutch pulled in.
My 01 might be saved.
Chet[img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 11, 2003 | 07:54 AM
Blksnshn's Avatar
Well I still haven't gotten the magneto off yet so i can't tell you if the o-ring works or not. Any advise on how to get this damn thing off?
Old Mar 11, 2003 | 10:23 AM
warrior007's Avatar
Originally posted by: airraptor
well the oring will work for a temp repair. but in about a years time the o ring being made out rubber and subjected to heat and oil will eventually stretch and will fail.
Alot of people replacing one-ways over and over would say the crap they get from yamaha is a temp fix, LOL. They may or may not be replacing the gear at the same time which I think factors in.
Old Mar 11, 2003 | 11:27 AM
Blksnshn's Avatar
hoooooaaaa finaly got this thing off, heat and hammer baby, yeah[img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 12, 2003 | 09:58 AM
Blksnshn's Avatar
OK guy the oring workes for about 4 starts, Guess it was to goo to be true....
Old Mar 12, 2003 | 10:29 AM
warrior007's Avatar
did it break? what kind of o-ring was it? What kind of shape were the sprags in before the o-ring.
Grant said he took the sprags out and spaced the bad ones out evenly.
Old Mar 12, 2003 | 01:12 PM
Blksnshn's Avatar
I haven't taken it apart yet to see if it broke or was sliping or what but the spraggs looked pretty good and I spred the worst ones out as best I could, and It was just a rubber oring from ace hardware, I'll let you know if it is broke, maybe I just need a higher quality oring.
Old Mar 12, 2003 | 02:11 PM
warrior007's Avatar
That might be it, atleast the flywheel may come off a little easier for you now.
