Fastest 300 foot sand drag times??
Like they said set up is key. Believe it or not I have seen a raptor with a pipe in the low 5.0 range but the kid weighed about 100 pound and the bike sat about 2 inches off the ground and had a wheelie bar also. My bike with a 180 pound rider with high compression piston, cam , and pipe was turning 5.5 in 300 ft. So I would say a good 50-60 horsepower bike with the right set up would probably run close to the high 4.0 and low 5.0
#15
I run on sand. There is a sanctioned sand drag strip just 5 miles from my house. Have not ran the 690 yet March 22 will probly be the date for that
. But that is running with a wheelie bar and sand skate 2's. the drag strip is 300 ft with a christmas tree nad the lights are set up sportsman style.
#16
14 - if i can get a stock predator to go 5.67 in 100 yards of SAND then a 100 hp should easily go in the mid to upper 4's if the driver is capable and the gearing and suspension is setup for that kind of power.
just for referance, there is a suzukie 1000 in a LT500 that is modded with NOS. i have seen him go as quick as 3.9....BUT he is pushing over 200HP. on average his times are 4.1 - 4.2
tubo bobby
tubo bobby
#18
Weight has alot to do with ET's. I figure that my Pol is putting around 65 to the ground and with me (250 lbs) I run high 5.1's low 5.2's. With the same 100 lb. rider that Redblue is talking about, the Pol ran consistant low 5.0's. With me, rider and quad=680 lbs. Quad and rider needs to go on a serious diet.
Jay
Jay
#20
