turbo for raptor
Old 03-22-2003, 03:38 AM
sandjunky660's Avatar
Default turbo for rator
has anybody put a turbo there raptor and did u build your motor? have a blow tran and its all apart. just trying see if i should build it natural or force feed. mr.turbo makes a kit that put out 70+ on 7lbs. is this kit good or are there others out there that better for the buck?
Old 03-22-2003, 07:06 AM
vilnrk's Avatar
i have the mr turbo kit on my raptor.
it will destroy the transmission.......which destroys the rod...which destroys the piston...which destroys the sleeve....which is why it is still down.
turbo bobby
Old 03-22-2003, 06:35 PM
Yamaharacer's Avatar
Has anyone made a Fuel Injected Raptor? How often do you have to work on the turbo? Are they really that unreliable.
Old 03-24-2003, 11:25 PM
vilnrk's Avatar
the turbo is totaly reliable, never a problem with the turbo.....its the weak yamaha gears thats not reliable......[img]i/expressions/face-icon-small-tongue.gif[/img]
turbo bobby
Old 03-24-2003, 11:31 PM
if tran is good(an 02) is the rest of the motor fine? how many pounds did u run on a stock motor? is there lag with that kit from mr .turbo and is it a good kit?
Old 03-24-2003, 11:39 PM
vilnrk's Avatar
Default turbo for raptor
lag...as in turbo lag...or lag as in dragging their feet to ship a turbo kit....haha well actually both, there is turbo lag and it took 3 months to get the kit.
if it is turboed then there is going to be turbo lag, just part of it i guess
the turbo comes setup at 7psi but is easily adjusted to make more psi, i have turned it up to 15psi.....that is when the transmission went BOOM.
turbo bobby
Old 03-24-2003, 11:46 PM
what all did u have to do so it will take 15psi? that seems like alot for a stock bottom. did o dyno it with 7 or 15psi and do u need biger carbs? thanks for the help,trying to make my mind up!
Old 03-24-2003, 11:47 PM
superslyjones's Avatar
my sisters bf has the raptor turbo.....he went and had custom titanium gears made....he ripped the heck out of his first tranny (01')...now with the new gears he is running 11 pounds and seems like nothing can keep up with him on the strip....he has over 10 g's just in the motor...lol....yeah it moves....but i don't know what his quarter times are or anything but yur right....a entire turbo setup and doing it right will be about 5 g's
Old 03-24-2003, 11:53 PM
vilnrk's Avatar
sandjunky you should call mr turbo and talk to them fellas about the turbo and how you increase boost. its been a long time since i have even looked at mine. its like bolting a grenade to your engine keep turning it up and sooner than later it will the blow engine to pieces....
turbo bobby
Old 03-25-2003, 12:14 AM
What do you have to do to change the boost? Ive read that you can change the boost with a button on the handle bars. What are your opinions on a 727 like KINGRAPTORS or AIRRAPTORS with a Turbo, NOS, and ALKY? How long tell is blows, what kind of numbers, how reliable and any other comments.
Thanks
Quick Reply: turbo for raptor
