12 Tooth Front Sprocket on 02 Raptor???
Old Mar 29, 2003 | 05:15 PM
jerstilly's Avatar
Default 12 Tooth Front Sprocket on 02 Raptor???
I would just like to get evryones opinion on doing this, if you have done it. What type of riding is it good for and how much MPH do u lose on top end. Also has anybody done this when they have it piped, and jetted. Thanks for the info.
Old Mar 29, 2003 | 06:39 PM
RacinJason's Avatar
Didn't loose that much MPH because it was able to pull a higher RPM with that gearing. I had that gearing until I pumped the motor and loved it. Cheap horsepower
Old Mar 29, 2003 | 07:43 PM
RaptorOwner's Avatar
It sure did get me out of the hole faster. I did notice some HP loss at top end at 5th gear.
Old Mar 30, 2003 | 01:27 AM
iamchad2k5's Avatar
wow. 12 teeth? whats the rear sprocket at?
Old Mar 30, 2003 | 03:27 AM
RaptorRacer1's Avatar
I ran a 12 tooth all last year. I race GNCC XC and mostly ride trails. The smaller sprocket let me lug it in 2nd gear on tight, twisty, rough trails so that I wouldn't have to shift into 1st. It does give you a noticeable boost in accelleration in the lower gears.
This winter I added full Elka suspension, a high-flow aluminum airbox, and a Dyna CDI, so I can run the same trails at higher speeds than last year. I have now gone back up to 13 tooth to gain my top end back for the straights.
If you ride woods or other tight trails, or MX where you don't ever max out in 5th gear, I would highly recommend it for a semi-stock Raptor. Once you start getting into engine work and higher HP, you don't need it. JMO. Good Luck!!
RR1
Old Mar 31, 2003 | 01:13 AM
maddog56's Avatar
I have a 12 tooth on my stock 03, and am very happy with the changes ive seen. I initially changed it because of my paddle tires, but now that I have ridden in on trails, i love it. I am able to beat my cousin and his 02 stock rappy out of the hole, and all the way through 4th. Its only after about a quarter mile does he start to catch me again, and very very slowly, maybe 2 mph, but thats giving it a lot. results were the same when we switched riders, he ordered a 12 toother the next day.
joeyupton
Jul 14, 2015 11:51 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
