Question on engine tear down
Old Mar 30, 2003 | 11:01 AM
ClutchOlds's Avatar
Default Question on engine tear down
When removing the flywheel to remove the crank. The manual calls to use a flywheel puller. I have the standard gear puller or harmonic balancer puller. Is this what you guys used to remove the flywheel. Just wanted to make sure. It seemed a little tough and didn't what to F#%K it up. Thanks for letting me know.
Old Mar 30, 2003 | 11:39 AM
wshrdskin's Avatar
Yes, thats what I used. As long as the bolts line up with the threaded holes on the flywheel that puller will work for you. The flywheel is tough, once it breaks free it may actualy pop off the shaft instead of slowly pulling off.
KimSJoh
14
Jul 18, 2015 07:20 PM
1966F100
Jul 12, 2015 03:08 AM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
D-Hagz
Jul 4, 2015 02:19 AM
