sprocket
Old Mar 31, 2003 | 10:05 PM
blaster2003kdk's Avatar
Default sprocket
do u got put news sprockets on when u get new rimes an tires for a 2003 blaster
Old Mar 31, 2003 | 10:08 PM
maddog56's Avatar
Default sprocket
that depends on the size of the the tires. If you got rid of those darn balloon tires and upgraded to a smaller, nicer tire, then you may want to go up a tooth in the front, depending on how much smaller the tires are. If they are only a little smaller, you could change the rear sprocket 1 or 2 teeth.
Old Mar 31, 2003 | 10:10 PM
Default sprocket
iam gettin razor 20x9 on the back what size sprocter should i get.or 20x8
Old Apr 1, 2003 | 12:52 AM
RaptorRacer1's Avatar
Default sprocket
If you leave the sprockets stock with the new tires, you will notice a good improvement in accelleration. You may lose a little bit of top speed, though. So it all depends on what type of riding you do. If you ride MX or woods or tight trails, I would leave it stock for the better accelleration. If you ride desert, dunes, or wide-open areas where you want top speed, I would go up one tooth in the front sprocket.
Either way, your most noticeable difference will be in handling. You will get alot better traction all around. Have fun!
RR1
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
