? on oil change/reading/amount
Old Apr 6, 2003 | 10:24 PM
warrior86's Avatar
Default ? on oil change/reading/amount
o and btw, its a new engine and i let it drip for over an hour, so there may be less in my crankcase, then the average person changing his oil. So maybe i was starting a little behind for teh begginning.
Old Apr 6, 2003 | 10:44 PM
snowbuster's Avatar
then why whenever i check my oil is it always way above the max. its always that way. and i put in the exact amount.
Old Apr 6, 2003 | 10:57 PM
warrior86's Avatar
yep, i know how ya feel. Nordy did a pretty good job answering the question tho.. Its just these damn dry sumps. There inconsistent. I guess if you put in the right amount and you dont burn oil...dont worry about. Thats how im about to feel pretty soon cause i pretty much give up.
Old Apr 7, 2003 | 12:54 AM
Nordy's Avatar
The trick I've found is to warm up the motor then let it set there for a minute or so then start to check it. You need the oil to settle in the tank so once the bike warms up shut it down then do a little clean up empty quarts of oil filter box etc... then check it and re check it to see where you stand. You might need a little more then 2 quarts if you let it drip for awhile. The only thing that I'd be worried about is too much oil in the motor excess psi and might get some blow by or something. I was the same way when I frist got my raptor you'll get used to it.
Old Apr 7, 2003 | 10:23 AM
  #15
warrior86's Avatar
and when i did the change, i took two quarts out..so they probably put 2.4 in cause dont new engines burn oil?
Old Apr 7, 2003 | 12:07 PM
  #16
warrior86's Avatar
and nordy, there cant be too much oil in the engine causing blowby if its 4/5 in the ok area...correct?
Old Apr 7, 2003 | 08:06 PM
  #17
Nordy's Avatar
That should be good. Just keep a eye on it just in case.
Old Apr 7, 2003 | 08:42 PM
  #18
warrior86's Avatar
what happens when there is blowby?. ..does it do permanet damage? Are theere any signs of it?
Old Apr 7, 2003 | 09:37 PM
  #19
warrior86's Avatar
and is 2 quarts what everyone else who owns a raptor puts in? How low does it have to be to do damage....like 1 quart?
Old Apr 7, 2003 | 10:27 PM
  #20
warrior86's Avatar
and how much do u have to over fill it to be dangerous? thanks in advance for your promp and educated responses!
