banshee problem
Old Apr 13, 2003 | 05:12 PM
pureinsanity's Avatar
Default banshee problem
Something else you could check is your need on your slide i had one of the e clips break and the needle fell to the bottom it would idle fine but wouldn't rev
Old Apr 13, 2003 | 05:17 PM
Guest
Guest
Posts: n/a
Dunepilot>>>> LOL "swinger springs" ! tell me about it....... PM me your E-mail addy....
or just say it out loud...
liquidsand
Old Apr 13, 2003 | 10:47 PM
DunePilot858's Avatar
It should be under my profile but if not... sanddiegoduner@yahoo.com
Old Apr 15, 2003 | 04:45 PM
BitchenBanshee's Avatar
check your jets in your carbs, you could be getting to much fuel to one side, i had the EXACT same problems, pulled hte carbs several times, new plugs, everythong, i tended up being that the littl washer that ogers under my main jet in one carb was missing, and letting to much gas in and fowling my plug right away as i would rev it up, it would idle fine, then run bad, that fixed it, i have also heard of other people haveintg this same problem, might check that out.
Old Apr 18, 2003 | 03:12 AM
  #15
Well it turned out being a serious but minor problem. All I can say is it runs good now.
Old Apr 18, 2003 | 10:59 AM
  #16
bansheeridr's Avatar
So, what was the problem my guess would be to check the parkingbreak, then the plugs, and then on the banshee is has a Throttle override system that sits on top of the carbs. When you take off your seat you can see them. Wiggle them and see if they are loose if they are thats your problem.
Old Apr 18, 2003 | 01:47 PM
  #17
Parking brake is removed, TORS units removed and replaced with carb caps and idle kit. It does idle a little high but its not so high I would be concerned.
Old Apr 18, 2003 | 01:57 PM
  #18
Guest
Guest
Posts: n/a
Its all fixed now thanks to dunepilot.. the guru...[img]i/expressions/face-icon-small-cool.gif[/img]
Yeah it was a minor but VERY serious problem.... Lets leave it at that...lol
liquidsand
Old Apr 18, 2003 | 02:13 PM
  #19
Batoutahell's Avatar
Oh, come on let us know what the problem was. You might help someone else out.
bat
Old Jul 27, 2003 | 05:45 PM
  #20
minimansion's Avatar
liquidsand
can you let me know how you fixed it? I have the same exact problem right now....
-minimansion
eddief@minimansion.com
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
